Overheating & Antifreeze Emptying Into Overflow
Old Jun 17, 2013 | 12:53 PM
tsingerjr's Avatar
tsingerjr
Is there a way to test the Thermostadt or do I just need to replace it?
Old Jun 17, 2013 | 12:57 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Originally Posted by tsingerjr
The lower raditior hose was burning up and the upper hose was cool. Is that normal, after running it for about 5 minutes?
It's supposed to be the opposite. The lower rad hose is what is bringing in cooler water into the water pump. I would say the t-stat is stuck shut but that would likely blow hoses.
Pull the t-stat and drop it into boiling water, put a thermometer in the water and see if it opens around 190*.
Old Jun 17, 2013 | 12:58 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Replace it, get a Stant Super Stat.
Old Jun 17, 2013 | 01:01 PM
tsingerjr's Avatar
tsingerjr
Ok... Im off to Advanced Auto. I'll keep pyou posted.
Old Jun 17, 2013 | 01:10 PM
zman17's Avatar
zman17
Test the new T stat also as described by the dude.
Old Jun 17, 2013 | 05:06 PM
tsingerjr's Avatar
tsingerjr
I romoved the old thermostat and it was in pieces. I cant believe that, considering I just replaced it in December, when I did the plenum repair. I put in the Super Stat as zman17 suggested and it seems to be running ok. I'll test over the next few days. Thanks for your quick responses guys!!!!
Old Jun 17, 2013 | 05:09 PM
dodge dude94
Did you test the new one first?
