Manifold oil leak repair
Old May 19, 2013 | 08:17 PM
Adobedude's Avatar
Adobedude
Default Manifold oil leak repair
Thought I'd post this here...
The intake manifold on the Dakota was leaking oil on the Dyno from the front corner where you need to run a little bead of RTV...Guy helping me with the carb tune told me to clean everything up REALLY good with brake cleaner, spray it into the gap - rinse repeat, then squirt some RTV into the space and put a shop vac on any hole on the Valve cover but to make sure it was a tight fit and it would suck the RTV into the gap.
Sure enough...Sucked it right in, I added a little more and did it with less suction so the RTV would stay where it was leaking.
Saved me from pulling the intake, that's a good thing
Old May 20, 2013 | 09:39 AM
AtomicDog's Avatar
AtomicDog
Nice! Thanks for the tip..
