PLEASE HELP 2001 Ram 1500 5.2 stalling backfiring replaced alot still problems
in park I can't rev past 1600 rpm then it farts and pops and stalls replaced cap rotor wires plugs pick up coil fuel pump sawsalled off the cat and unplugged the o2 sensor pre cat and nothing worked replaced and now i can't even shift into drive it farts pops and backfires until i take my foot off the gas then it stalls.
2 days away from junking this truck and never buying dodge again PLEASE HELP!!!!! |
I did look in the other thread then post those answers here.
I know there are other post out there like this but none have been solved
timing is good all marks aligned etc how do i check the fuel pressure have never done it yet i have a gauge for some reason pump is a duralast
Download the 2001 factory service manual from the FAQ's section.
It will explain how to check pressure. Dave |
thanks jarhead
Head over to the diy 2nd gen area and Dl the 2001 fsm page 1497
DIAGNOSIS AND TESTING - FUEL PUMP PRESSURE TEST Use this test in conjunction with the Fuel Pump Capacity Test, Fuel Pressure Leak Down Test and Fuel Pump Amperage Test found elsewhere in this group. Check Valve Operation: The electric fuel pump outlet contains a one-way check valve to prevent fuel flow back into the tank and to maintain fuel supply line pressure (engine warm) when pump is not operational. It is also used to keep the fuel supply line full of gasoline when pump is not operational. After the vehicle has cooled down, fuel pressure may drop to 0 psi (cold fluid contracts), but liquid gasoline will remain in fuel supply line between the check valve and fuel injectors. Fuel pressure that has dropped to 0 psi on a cooled down vehicle (engine off) is a normal condition. When the electric fuel pump is activated, fuel pressure should immediately (1–2 seconds) rise to specification. All fuel systems are equipped with a fuel tank module mounted, combination fuel filter/fuel pressure regulator. The fuel pressure regulator is not controlled by engine vacuum. WARNING: THE FUEL SYSTEM IS UNDER CONSTANT FUEL PRESSURE EVEN WITH THE ENGINE OFF. BEFORE DISCONNECTING FUEL LINE AT FUEL RAIL, THIS PRESSURE MUST BE RELEASED. REFER TO THE FUEL SYSTEM PRESSURE RELEASE PROCEDURE. (1) Remove protective cap at fuel rail test port. Connect the 0–414 kPa (0-60 psi) fuel pressure gauge (from gauge set 5069) to test port pressure fitting on fuel rail (Fig. 11). The DRBt III Scan Tool along with the PEP module, the 500 psi pressure transducer, and the transducer-to-test port adapter may also be used in place of the fuel pressure gauge. (2) Start and warm engine and note pressure gauge reading. Fuel pressure should be 339 kPa 6 34 kPa (49.2 psi 6 5 psi) at idle. (3) If engine runs, but pressure is below 44.2 psi, check for a kinked fuel supply line somewhere between fuel rail and fuel pump module. If line is not kinked, but specifications for either the Fuel Pump Capacity, Fuel Pump Amperage or Fuel Pressure Leak Down Tests were not met, replace fuel pump module assembly. Refer to Fuel Pump Module Removal/Installation. (4) If operating pressure is above 54.2 psi, electric fuel pump is OK, but fuel pressure regulator is defective. Replace fuel filter/fuel pressure regulator. Refer to Fuel Filter/Fuel Pressure Regulator Removal/Installation for more information. (5) Install protective cap to fuel rail test port. |
Fuel Pressure is absolutely perfect needle reads about 50 psi at idle dont know how to check when it acts up because it wont stay running
any other suggestions I noticed if i feather the pedal after it runs rough i can get it to idle hence how i checked fuel pressure i'm so stumped its not the injectors either. Might be a for sale sign on it soon if not
Download the service manual as stated. With it and a cheap multimeter you can test most if not all the sensors. Coil replaced? Crank sensor replaced? You didn't remove or turn the distributor did you? What brand parts are you buying? (like the cam sensor). Did you remove the negative battery cable while replacing or cleaning sensors? Have you tried cleaning IAC and throttle body?
