Too big of Injectors?
Old Jun 3, 2013 | 06:17 PM
Deadlymopar408's Avatar
Deadlymopar408
Default Too big of Injectors?
360 bored .030 with .480 gross lift camshaft, I put 24lb injectors in and I have reason to believe its the cause of m shaking when the truck reaches the final gear. I already replace the torque converter b/c the tech I talked to said it is possible that the lock up was malfuctioning. But when I do 60 their is a bit of shaking but not as voilent.
Old Jun 3, 2013 | 09:19 PM
stewie01's Avatar
stewie01
Being a '94 a "tuner" is out the question, but wouldn't you need some kind of custom programming for that setup?
Old Jun 3, 2013 | 09:52 PM
Deadlymopar408
Never mind figured it out the injectors were too big i swap back to the stock and it runs way better and the cpu is already programmed for the larger camshaft the shaking is no more
Old Jun 3, 2013 | 10:00 PM
stewie01's Avatar
stewie01
Sweet! Glad you figured it out
Old Jun 3, 2013 | 10:09 PM
Spillage's Avatar
Spillage
I plan on trying some Bosch#0280155784
They're 4 port (EV6) 22.3lb/hr@43.5psi (23.7@49psi) 12.5ohm... that's only 0.5lb/hr at rail pressure more than stock, and the coil is the same resistance.
These are as close as I could find at rail pressure without being less.
Some options also had coil resistances way different, which I figure would effect response time.
I'll let you know how they work out in a week or so.
Old Jun 10, 2013 | 09:16 PM
Deadlymopar408
That would be great to hear if they work b/c now the truck sounds like it could use alittle more juice my motor has a 11:1:1 compression and I'm kinda far away from a dyno shop to figure out some of this **** lol
Old Jun 10, 2013 | 09:47 PM
Spillage's Avatar
Spillage
A Wideband Air/Fuel gauge should tell you if you're over or under fueling.
