Aftermarket Radio Issue
I have a JVC head unit that I have installed, but when i go to crank the truck (2000 1500) or give it auxiliary power, the head unit will turn on for a second (the screen on it will say goodbye) then turn off. I have the hot wire from the head unit connected to the ignition power wire instead of the constant power wire. Any ideas of how to solve this?
Dodge has a pink wire which is the constant power source and a red with a white strip which is the ignition power source that were connected to the original equipment head unit.
Like I said, I don't know enough about stereo install. I do know that plug and play harnesses are sold. I'm sure someone else will chime in sometime today with a lot better info than I can provide on this topic.
If I remember correctly, the yellow wire is the constant power. This is to keep the memory settings. Red is the ACC/ignition power and black is ground.
You want the red wire from the head unit attached to the Red / White wire from the truck.
The yellow wire should attach to the Pink wire. It may also be pink/white.
For the ground wire, just attach it to a bolt head some where in the dash that is metal.
