check engine flashing and studdering
Old Jun 13, 2013 | 10:36 AM
DoubleL24's Avatar
DoubleL24
i replaced plenum with one of the plenum kits think hughes kit. cat is gutted and i did the sparkplug non fouler for the 02 sensors. im going to replace plugs this weekend and ill see how the wires are. wires are fairly newer.
Old Jun 13, 2013 | 10:38 AM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Wait, which 02 sensors? If you did both, that's bad. You should have only done it with the post-cat 02, not the pre-cat.
Old Jun 13, 2013 | 10:39 AM
zman17's Avatar
zman17
Retired Moderator - RIP
You should add that info to your sig, so we know what all has been done to your truck. Anyway, check out the FAQ/DIY section. Lots of good info like this, https://dodgeforum.com/forum/2nd-gen...code-list.html
Old Jun 13, 2013 | 10:40 AM
Gary-L's Avatar
Gary-L
Veteran: Navy
Did you follow the TSB regarding the proper routing of the wires? Also, are you certain the wires are connected to the appropriate plug?
DoubleL24's Avatar
DoubleL24
right. i screwed pre cat in like normal and did it to the post cat
Old Jun 13, 2013 | 10:41 AM
dodge dude94
+1 Could have a split wire and it's crossfiring with another.
Oh, okay. That's good. lol
Old Jun 13, 2013 | 10:42 AM
DoubleL24's Avatar
DoubleL24
I dont know how to do add info to my sig. im on my phone and dont see anything. maybe ill try when im on a computer next time.
Old Jun 13, 2013 | 10:44 AM
DoubleL24's Avatar
DoubleL24
maybe ill replace plugs and wires to this weekend and go fr there.
Old Jun 13, 2013 | 10:51 AM
DoubleL24's Avatar
DoubleL24
whats a good brand for plug wires? theres so many hard to find a good brand.
Old Jun 13, 2013 | 10:52 AM
stewie01's Avatar
stewie01
Do the key trick, pull the plugs for the cylinders it says is misfiring. If it doesn't show any codes pull the plugs anyway and take a look at them before you buy a new set.
Stick to cheap copper cores.... Some like Champion some like Autolite, etc...
