engine pops and revs high and low
Old Jun 17, 2013 | 10:36 AM
trailblazin joe's Avatar
trailblazin joe
Default engine pops and revs high and low
I have an 01 318. Recently the engine started popping and sputtering, but it never stalls. When I stand on it the misses from the engine basically stop, but as soon as it reaches a cruising speed it will periodically pop and sputter. I have changed the plugs, wires, dist. cap, rotor, throttle position sensor and have ran the codes, which indicated a vapor leak. I had a smoke test done and found no leaks. The engine has 112,000 miles on it and I have installed a cold air intake. Also when I start it up it will idle fine for a few minutes, and then right on cue, it will make a sound like a jet engine revving up and then it will idle very rough, with the truck shaking from the rough idle. I am at a loss and have been told that this is very common to this truck and no one really has been able to help me out.
Old Jun 17, 2013 | 12:15 PM
zman17's Avatar
zman17
Retired Moderator - RIP
O2 sensor maybe.
Old Jun 17, 2013 | 12:18 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Sounds like possibly a combination of a bad IAC and front 02 sensor, but that's just me.
Old Jun 17, 2013 | 12:52 PM
zman17's Avatar
zman17
One can always try cleaning the IAC and TB. Remove negative battery cable before doing so, remove it if replacing the o2 also. https://dodgeforum.com/forum/dodge-r...n-the-iac.html
Old Jun 18, 2013 | 08:46 AM
trailblazin joe
Would either of those thrown a code?
Old Jun 18, 2013 | 02:16 PM
zman17's Avatar
zman17
Nope, not always.
Old Jun 19, 2013 | 04:11 PM
gertie240's Avatar
gertie240
+1 on the TB and IAC cleaning, cheapest fix first.
Old Jun 19, 2013 | 09:42 PM
trailblazin joe
I have tried the TB and IAC already to no avail, I am going to disconnect the O2 sensor tomorrow and see where that leads me.
