dodge nv4500 question
Old Jun 22, 2013 | 01:39 PM
JeremiahPatterson's Avatar
JeremiahPatterson
Default dodge nv4500 question
does any one know how to replace the input and output shafts on a dodge nv4500 5 speed and how do you tell what gear ratio it is ? thank you
Old Jun 22, 2013 | 01:44 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Not sure it will give ratios, but download the 01 service manual from the FAQ/DIY section. I'm sure it must have the rebuilding procedure in it.
Old Jun 22, 2013 | 02:09 PM
PrestonEidsmoe's Avatar
PrestonEidsmoe
The Transmission identification number is located on a tag secured by two bolts to the power take-off-cover. My numbers are 2108225 DF 10 20 95 4500 D You will find the difference in gear ratios is in your axles and transfer case (If I am not mistaking?). I am new here but, not new to wrenching and building rigs.
Old Jun 22, 2013 | 02:18 PM
zman17's Avatar
zman17
might help. http://dodgeram.org/tech/transmission/nv4500_spec.htm
Old Jun 23, 2013 | 03:09 PM
PrestonEidsmoe
That is a great link there Zman! Thanks.
