How to clean a keg ?
Old Jul 1, 2013 | 04:11 PM
  #21
Action Potential's Avatar
Action Potential
I've used easyoff oven cleaner on steel valve covers. It works better if you leave them in the sun. It may remove the paint... If the covers are power coated, it damages the finish. Baked epoxies hold up best.
Old Jul 1, 2013 | 07:23 PM
  #22
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
I missed your post, yes but always to a small test area first. It's a old Hot Rodders trick, Google search has info about how to do it and what metals it works on.
Cool.
I'm not really worried about the paint as the paint is 36 years old. lol
I had said something to my dad about it and he said "Yeah, now I remember". lol He used to do that back when he had his Fury.
Old Jul 1, 2013 | 08:21 PM
  #23
AtomicDog's Avatar
AtomicDog
Originally Posted by redneck_ram
m1's have been discontinued so theyre going to be pricey-er, and even more rare now.
Should be able to find them on the used market reasonably priced. For example, I could have bought one off our local craigslist, but decided the kegger was fine for my needs after speaking with the owner about his experiences with it.
Old Jul 1, 2013 | 10:33 PM
  #24
Action Potential
Update: I broke down an got a 5 gal drum of chem's carb cleaner. 4 hours later... clean... no rust, no dirt, no "organ goop".. Bead blasted the rest clean
Well, if this doesn't work and I decide not to buy a new truck, I'm ditching this keg for an edelbrock manifold or an rebuilt engine..
thanks for all the help..
Old Jul 1, 2013 | 10:49 PM
  #25
dodge dude94
You'll need a new cat and front O2 sensor as well.
And there are no Edelbrock intakes for these engines. The Hughes Airgap is the only Edelbrock manifold and even then it's modified for the MPFI system
Old Jul 2, 2013 | 12:13 AM
  #26
AtomicDog's Avatar
AtomicDog
Same thing I did with my kegger - properly install the new gaskets, bolts and aluminum plate and you will be just fine. As was mentioned, be sure to check the cat and O2 sensors. In addition, you may want to Seafoam the engine, once its back together and running. See the plenum repair thread for more details.
Old Jul 2, 2013 | 12:17 AM
  #27
dodge dude94
You might do a search on here for the Kegger mod, since you'd got it taken apart and will have it cleaned up...
Old Jul 2, 2013 | 11:24 AM
  #28
Action Potential
I looked at the mod... It a lot of work for relatively little gain. If I need much more out of a half-ton, I'll move to a 1ton or more..
Old Jul 2, 2013 | 11:26 AM
  #29
Gary-L's Avatar
Gary-L
Veteran: Navy
HA! Kegger mod, lightly porting and polishing the heads along with a Fastman throttle body really wakes up both the 5.2L and 5.9L.
Old Jul 2, 2013 | 11:41 AM
  #30
Action Potential
Seafoam and o2 sensor already in the garage, And the cat... is 'less' clogged.
Now the cat is rattling around in there not doing too much. Still passes emissions, but the #8 plug is clearly little more fouled than the others.. Still not so bad..
I was thinking of changing the exhaust to improve the mileage. I flattened the mid pipe a bit and shattered the tail pipe hanger when I dropped the truck... didn't see an 18 inch cliff at 30mph. The rear shock mounts exploded and came out in pieces.. Never seen anything happen like that before.
