emmissions leaks
Old Jul 2, 2013 | 01:47 PM
brownhunter's Avatar
brownhunter
Default emmissions leaks
Last week my check engline light came on. It said evaporative emmissions leak, small leak. Truck ran fine. I cleared the code to see if it would come on again. Two days ago it did. This time saying it was a large leak. Then I when out to go fishing yesterday, the light was flashing an the engine was struggling for a short time going up hill at about 1000 ft elavation while towing the boat. Well I stopped to look around and gassed in in park and neutral. Nothing happened. Truck ran normal going up hill the rest of the way to the lake which was at 5000 ft. What the deal? I don't see any bad hoses in the engine.........? Any help would be great! It's a 2001 1500 5.9 4x4 ram.
Old Jul 2, 2013 | 02:11 PM
Matt Nickerson's Avatar
Matt Nickerson
Well obvious things first.. Did you leave your gas cap at the gas station by chance?
If it's still there and screwed on right check ALL the evap hoses; under the hood and at the charcoal canister on the frame rail.
Old Jul 2, 2013 | 07:38 PM
brownhunter
Yeah I still got my cap!! Perhaps the seal on it is bad? I check them, once it cools down, it is about 106 outside right now! haha. It won't hurt the engine to keep driving with this problem right?
Old Jul 2, 2013 | 08:52 PM
dhvaughan's Avatar
dhvaughan
you have multiple cracked vacuum lines at the purge solenoid (passenger side fender) and evap canister (under passenger side).
https://dodgeforum.com/forum/2nd-gen...-leak-fix.html
