1.25 body lift
Old Jul 8, 2013 | 10:19 PM
ramrookie92's Avatar
ramrookie92
Default 1.25 body lift
Im looking to install a 1.25 rough country body lift. What would i need to change and alter and would i need exstensions or drop brackets for.anything.
ramrookie92
Trucks a 2000 dodge ram 4wd
Old Jul 9, 2013 | 05:01 AM
ryan0714's Avatar
ryan0714
with only a 1.25" you wont need drop brackets for nothin due to all ur raising is the body. the brake lines will be fine. even with a 3" the brake lines will be fine. but your kit may come with a extension piece of bar stock to weld in the shift linkage. and it may also come with the extension for the gas filler neck. but im not sure it it will come with those, since its only 1.25". hope this told you something. its a pretty easy install.
