water in transmission 99 ram 1500 4x4
Old Jul 10, 2013 | 12:04 PM
sully5981's Avatar
sully5981
yea mine wasn't submerged that bad. It just happened that either something was splashing around and kicked in water above the tranny and the breather tube (hole, since i don't think there was a breather tube) sucked in water while i was trying to put it in reverse.
I too just wanted to do a few flushed and replace the tranny fluid however, once that pepto bismol pink looking creamy stuff gets in the transmission, it starts seeping in the seals and internals. It will never run the same.
Or it could be your cat, cause i had to fix mine as well. if you want to can go that route and see if your cat is clogged.
Old Jul 10, 2013 | 12:07 PM
sully5981's Avatar
sully5981
Originally Posted by bsimmons1990
@ sully 5981
no iwasnt that deep. my driverside was deep enough that water was coming in my cab. i kept my truck running when i was stuck if that gives u a idea. i drove it 2day n it drove good, shifted good. just that OD gear with the different rpms now.
Yea i was able to drive mine home with only it sounding like it had a cold (water in the cat)
Old Jul 10, 2013 | 10:29 PM
bsimmons1990's Avatar
bsimmons1990
not the cat, i have just pipe. when i was stuck, i kept my truck running so water wouldnt get in the exhaust. it hasnt ran right since i got it stuck... i think my breather tube is not there n thats how it got in. when i was driving it earlier 2day, it didnt want to shift till 21/2-3 rpms. i think im gonna have 2 replace it...
Old Jul 10, 2013 | 10:47 PM
dhvaughan's Avatar
dhvaughan
Sounds more like you are getting TCC engagement. Should be around 1500 RPM at 55 in O/D with TCC engaged.
Try driving at 55, see where your RPMs are at, and LIGHTLY step on the brake. See if RPM jumps a bit. (I bet it doesn't. )
^+1. TCC is a 300 rpm drop. OD is about 500.
i don't know much about them, but i'd guess ther is an electric TCC solenoid that's not working.
