1995 ram 1500 difficulty starting
Old Aug 31, 2013 | 11:36 AM
razorback79's Avatar
razorback79
Exclamation 1995 ram 1500 difficulty starting
When I first start the truck, everything is fine, but let's say I drive for an hour and stop at the store. When I try to start it again to leave, it takes two or three tries to do it. I've already changed the spark plugs, the distributor cap, and given the truck a tune-up. Anyone know what may be the problem?
Old Aug 31, 2013 | 11:53 AM
gertie240's Avatar
gertie240
sounds like the fuel pump is overheating. does it make a difference if the tank is empty or full? Do you have a habit of running low on fuel? The gas actually keeps the pump cooler.
Old Aug 31, 2013 | 02:19 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Get a Haynes manual and a cheap multimeter. Sounds like you might have a bad engine coolant temp sensor or even a bad IAC. With the meter and manual, you can test most of the sensors.
