Front dana 44 ?
Old Sep 5, 2013 | 04:37 PM
getdown78's Avatar
getdown78
Default Front dana 44 ?
Will older chevy or ford Ring & Pinion fit the front housing of a 96 1500 or the jeep gears ?
Old Sep 5, 2013 | 06:40 PM
Rescue35's Avatar
Rescue35
Any low pinion gear set will work. A lot of Fords where high pinion.
Old Sep 5, 2013 | 07:20 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can find your answer here, do the parts look up from what you have to what you want to put it in, and see if the part numbers match. http://www.ringpinion.com/
Old Sep 6, 2013 | 09:51 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Not enough information here on what you have in hand. It seems like you are saying you have or can get chevy/ford R&Ps. However, what year are you talking about, just for starters? I wouldn't expect much difference other than whether high or low pinion.
There are no "jeep" gears.
You'd be cross referencing part numbers of R&P across Dana 44.
Old Sep 6, 2013 | 10:29 AM
getdown78's Avatar
getdown78
Like the late 70's ford front dana 44's and the 75-87 chevy dana 44's ? I figured if i could find some good used gears for my front on a deal i would buy them if they will fit !
Old Sep 6, 2013 | 11:29 AM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Here you go....have at it and come back with what you've found "works".
http://77cj.littlekeylime.com/web_rs44.html
Edit: Also these
http://www2.dana.com/expertforms/depdf.aspx?prod=AXL
http://www2.dana.com/pdf/5310-3.pdf
