46RE Low transmission fluid. Just touching dip stick..
Old Sep 10, 2013 | 04:29 PM
Rpm90001's Avatar
Rpm90001
Default 46RE Low transmission fluid. Just touching dip stick..
fluid is just touching dip stick, how much to should I add to get it to the ok mark. 2 Quarts? New to me truck...just checked it for first time and it was just touching the tip slightly. No shifting issues...no leaks visible.
Old Sep 10, 2013 | 04:34 PM
dodge dude94's Avatar
dodge dude94
Banned Goober Smoocher
Throw a quart in and see where that gets you.
Might be 1.5-2 qts, but put one in for now.
You need to figure out where it's going though.
Old Sep 10, 2013 | 06:27 PM
Rpm90001's Avatar
Rpm90001
Picked up 2 quarts one didn't do it..took 2 Thanks. I didn't want to buy too many, but didn't want to make an extra trip to get more.
Thanks.
Old Sep 10, 2013 | 07:45 PM
dodge dude94
To be honest, you can never really have TOO much ATF+4.
You might need it for SOMETHING (ie, steering box, buddies truck, etc).
Old Sep 11, 2013 | 04:34 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You did check the fluid level with motor running and tranny in neutral right?
Old Sep 14, 2013 | 08:08 AM
Rpm90001's Avatar
Rpm90001
Yes, running,in neutral. Also ran through the gears. The truck is new to me. I did not check the level when I bought. I checked color and smell, but not level.
I will have to watch it. No wet spots on transmission,or ground. No leaks. But for all I know it was never checked by last owner. Last owner was in her 80's and bet she wasn't on to check it often or at all. Actually added 2.5 quarts total. Added another 1/2 quart to bring it up to perfect on dip stick.
Old Sep 15, 2013 | 09:19 AM
newman1367's Avatar
newman1367
It's a little late now, but since it was new to you and low, you should have dropped the pan. Adjusted the bands, replaced the filter and put 4 quarts back in.
