Air conditioning compressor
Old Sep 15, 2013 | 06:10 PM
Ziggy2112's Avatar
Ziggy2112
Default Air conditioning compressor
I have a terrible noise coming from my ac clutch. Sounds like a bearing noise ( metal on metal)
I understand that you cant buy just the clutch, but have to get the whole compressor???
My ac works great, just noisy, (sound is less with ac ON)
Any ideas, or recommendations? Is there a bypass pulley kit avaliable on the 98 5.9?
Old Sep 15, 2013 | 06:25 PM
getdown78's Avatar
getdown78
Cheaper and easier to buy a new compressor !
Old Sep 15, 2013 | 07:13 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Can't help on the a/c but here is a bypass pulley for ya on Ebay.
http://www.ebay.com/itm/New-Dorman-A-C-Delete-Pulley-AC-Compressor-Bypass-FOR-94-01-DODGE-RAM-TRUCK-/330744304861?pt=Motors_Car_Truck_Parts_Accessories&hash=item4d01e594dd&vxp=mtr
Old Sep 15, 2013 | 07:33 PM
Once they make noise, easier just to replace the entire thing.
Old Sep 16, 2013 | 03:07 AM
beeker's Avatar
beeker
Try removing one of the shims. Remove the nut on the front of the clutch, gently with even pressure pull the front clutch plate off, remove one shim(tiny washer) see if that helps, if not, by pass pulley as stated above or compressor. The clutch kit is available on ebay too, just did mine recently.
Old Sep 16, 2013 | 02:48 PM
zman17's Avatar
zman17
Retired Moderator - RIP
You can replace the bearing.
http://www.ebay.com/itm/NEW-AC-COMPRESSOR-PULLEY-CLUTCH-BEARING-CROSS-35BD219DUK-35mm-55mm-20mm-35x55x20-/160935247937?pt=Motors_Car_Truck_Parts_Accessories&vxp=mtr&hash=item25787d0041
