4x4 problem
I have a 2001 5.9L 1500 and when I put it in 4H I hear a clicking sound when I turn and have no turning radius. I know 4x4 limits your radius, but I can only go straight or barely not straight. I know it isn't u-joints as I replaced those about 5k miles ago and the brakes are fairly new. Its only when turning too, 4x4 is perfect when going straight. Help?
clicking is probably u-joints in the front drive shaft. which did you replace - driveshaft or axle?
reduced turning radius is normal. our trucks are part time 4wd with no center differential.
Any slop at all in the u-joints, replace them, there's no other way. If they're clicking, it's time.
Trending Topics
What surface/terrain were you on? Were you on level ground?
