Body side trim ?.
Old Sep 22, 2013 | 10:57 PM
Ram Driver's Avatar
Ram Driver
Default Body side trim ?.
The rubber trim on the side of my 2000 Ram is coming loose and needs to be re-glued. What glue can I get that will hold the rubber trim in place ?. I want something good so I don`t have to re-glue it every few months.
Old Sep 22, 2013 | 11:19 PM
merc225hp's Avatar
merc225hp
3m trim tape, you can get it at most auto parts stores. Surface prep is the key to a lasting job.
Old Sep 23, 2013 | 12:30 AM
Ram Driver's Avatar
Ram Driver
The long rubber seal thats on the edge of the cowl under the hood has also come off on my truck, what type of glue or ? do you suggest I use to put it back on ?. I was thinking of using silicone if that would work ?.
Old Sep 23, 2013 | 07:55 AM
Silicone will work, also gorilla glue or contact cement.
