1996 dodge ram 1500 3.9 V6---THROWOUT BEARING
Old Sep 26, 2013 | 11:25 AM
bigred4591's Avatar
bigred4591
Default 1996 dodge ram 1500 3.9 V6---THROWOUT BEARING
Throw out bearing clips keep snapping and it looks like there is some wear on the back of the TOB. I have had to replace it twice in the past year and it is rubbing again. It rubs when in neutral and in gear. Only time it stops is when I fully press on the clutch or remove the slave cylinder while its in neutral. I don't know if I should replace whole clutch or slave cylinder. I also don't know if the TOB is supposed to fully come off the pressure plate when it is not engaged.
