How to deal with backseat rot?
Old Sep 26, 2013 | 10:00 PM
ShelbyGT550's Avatar
ShelbyGT550
Default How to deal with backseat rot?
Found this nice hole after removing the carpet -_-. Also are these rockers gone?
How can I (if i can) get rid of this rust so it does not spread or get worse?
Rocker
Old Sep 27, 2013 | 08:01 AM
Looks pretty bad. If it was surface rust it would be one thing, but you got rust through. You got to cut the bad stuff out or it will just keep spreading. You might be able to slow it down with some rust preventer stuff, but your best bet is to just cut it all out and replace.
Old Sep 27, 2013 | 09:57 AM
ShelbyGT550
How do I go about cutting that out though, Thats the problem. As it looks like the back of the cab mounts to it, and there is a "reinforcement" in the way thats spot welded
Old Sep 27, 2013 | 12:13 PM
ShelbyGT550
Any and all help is appreciated. I was devastated when I pulled the carpet and saw that. As I did not catch that when I inspected the truck before I bought it. I did not want another rust bucket. I take it the rockers will need to be replaced after our 'salt' winter? I love the truck and just replaced the trans, u joints, front drive shaft, brakes and calipers and drums and rotors all around. But I am almost thinking of selling it off now. I got no body work knowledge and have very little money
Old Sep 27, 2013 | 12:26 PM
Ham Bone's Avatar
Ham Bone
I had an old timer who said he had a friend who had a major rust problem in the driver floorboard, holes everywhere.
Apparently he just used some por-15 and covered it on paper towels and kinda made a floorboard. Swore by it. I wouldn't really recommend that
I have approximately 0 body work knowledge sorry
Bit if you have already done that much work to it might as well fix the body rust because then you'll have an extremely solid rust
Old Oct 4, 2013 | 10:18 AM
ShelbyGT550
Hopefully you ment "truck" not "rust" lol Its all repaired and reassembled, Need to get the lower latches for the rear doors though as both broke when I went to remove to sand the bottoms of the doors. Pics here : https://dodgeforum.com/forum/2nd-gen...x-rebuild.html
