Heater Problems
Old Oct 20, 2013 | 03:27 PM
RedneckMagnumPower's Avatar
RedneckMagnumPower
Default Heater Problems
Today, I flushed my heater core. I removed the hoses going in and out. I ran water both ways 5 times each until everything came out clear. Then I ran air through the hose going in. First at 20 psi, the 40, then 60.
I have warm air now, and both hoses are hot to the touch, whereas before the out hose was cool/barely warm.
The problem is, the air still doesn't stay warm for long, and after driving a little while warming it up, parking it for 5 minutes the temp guage goes down to halfway between 200 and 130. The temperature goes back to normal after driving for a couple minutes, and goes down when idling aain.
What are the recommendations for the heater, and what did I do to cause the temperature screwup? Maybe run clr through next time?
Old Oct 20, 2013 | 04:28 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
I'm suspecting the thermostat has failed, hence the reason for the fluctuating temperatures.
Old Oct 21, 2013 | 01:37 AM
RedneckMagnumPower
My grandpa went out there and burped it, the temperature is okie dokei The heater is warm, and consistent on recirc, but not hot. Should I run CLR through or up my pressure when I blast air through it. Thanks in advanced for any more help.
Old Oct 21, 2013 | 12:52 PM
zman17's Avatar
zman17
Retired Moderator - RIP
The heater core is most likely clogged. Even if you get clean water coming out, it doesnt mean some of the tubes are not clogged/restricted. And I wouldn't blast it out with too much air pressure, or you'll blow a hole in it. The heater core is a very common problem on these trucks.
