slipping 2-3 after adjusting bands several times
Old Oct 26, 2013 | 09:33 PM
99ramworkn's Avatar
99ramworkn
Default slipping 2-3 after adjusting bands several times
I have a 99 ram 5.2 auto. I replaced the solenoids and sensors. Fluid good. Adjusted the bands 5 times inthe past month. Some days it shifts fine. Other days it slips between 2nd and 3rd. Now that its cold it hesitates to go into third. I can leave second and rev and let rpms drop and rev again before bang 3rd. I have learned to pedal shift 2nd to third to reduce the bang of 3rd. To top it off I recently got rear ended by a civic. The car went under my bed hit my rear end and snappedmy drivers side leaf spring. After the fix im gitting a faint wine between 40 and fifty. Plz help
Old Oct 26, 2013 | 09:53 PM
99ramworkn's Avatar
99ramworkn
I doubt this matters but I have a cold air intake, msd 6a with a blaster coil, msd wires, and 3923 plugs. Recently replaced the iac and tps. In overdrive at lower rpms it feels like I shimmy till about 2000 rpms then it fades away. (I think I need a standard). I need something to tell the shop on monday instead of sounding like a moron. I dont want them to try to shrug this off like who cares its old. Insurance might pay for this!
Old Oct 26, 2013 | 10:00 PM
topkin's Avatar
topkin
Does it shift more smooth when you give it more gas from a stop as aposed to just easing into it or leaving a light at a normal pace, or is this a problem no matter the amount of pedal you give it?
Old Oct 26, 2013 | 10:25 PM
stewie01's Avatar
stewie01
You could try a TV cable adjustment, http://bionicdodge.com/Download/Dodg...Adjustment.pdf, but having issues after that many adjustments probably indicates a bigger problem, possibly even a rebuild.
How's the fluid looked when you dropped the pan?
Old Oct 26, 2013 | 10:41 PM
99ramworkn's Avatar
99ramworkn
When I step on it theres no problems in shifting. But easing it brings on the symptoms.the fluid smelled burnt and was dark red. I also had a lot of shavings onthe on the magnet. They were very finetho and I dont think anyone else ever droppedthe pan. I bought it with 72k and did the work at 80k. Amazingly the problems didnt start till about 80k. I have 81723 on it now. And how can this be made to look like a ccar accident did this. :-)
Old Oct 26, 2013 | 10:43 PM
99ramworkn's Avatar
99ramworkn
I did the tv cable adjustment which wasnt even an adjustment. It was fine in the first place.
Old Oct 27, 2013 | 08:50 AM
99ramworkn's Avatar
99ramworkn
What if I remove the return spring on the t.v. Cable! You think that will be clever enough to warrant a new tranny? Or do you think someone will be clever enough to find that?
Old Oct 27, 2013 | 08:51 AM
stewie01's Avatar
stewie01
It's probably time for a rebuild.
