Lost all lighting on right rear
Old Oct 26, 2013 | 11:14 PM
Jmarcin86's Avatar
Jmarcin86
Default Lost all lighting on right rear
I traded my 95 ram 2wd for a 96 ram 4wd and the right read tail light, back up light and turn signal or not working. Any clue on where to start looking to fix it?!?!
Old Oct 26, 2013 | 11:19 PM
gertie240's Avatar
gertie240
connection for the trailer lights
Old Oct 28, 2013 | 06:13 PM
Jmarcin86's Avatar
Jmarcin86
That worked! Thanks! Now any idea where to look on why the fuel gauge is reading empty?
Old Oct 28, 2013 | 08:10 PM
ryan0714's Avatar
ryan0714
either its not gettin power on the board, or the float is stuck on the pump.
Old Oct 28, 2013 | 11:04 PM
Jmarcin86's Avatar
Jmarcin86
It's weird because the low gas light comes on and off.... I can fill it up and it will go off for the 1st 4-10 miles then it comes back on. I'm just not sure where to look first or if have someone look at and replace all the gas lines and what not.
Old Oct 29, 2013 | 11:19 AM
gertie240's Avatar
gertie240
I have a similar problem, gauge reads when it wants. Have decided to live with it until I get around to pulling the tank and replacing the fuel pump assembly. You could try tapping on the side of the tank with a rubber mallet, or put some seafoam in the tank for a couple of fillups. That may loosen up the float, or the float may have a small hole in it. Good luck and let us know.
