2nd gen winter grille cover
Old Nov 1, 2013 | 02:57 PM
bigaaron's Avatar
bigaaron
Cool 2nd gen winter grille cover
Anyone have a good source for a cover i can use to help warm engine while I drive? or even a DIY
Old Nov 1, 2013 | 03:39 PM
Take a cardboard box and cut it to fit behind the grill.
Old Nov 1, 2013 | 08:13 PM
Jimythefan's Avatar
Jimythefan
I do the cardboard thing with a black trash bag cover (protects from moisture) during the coldest part of winter. It helps keep the temps up while running the 180 thermostat. I cover about 1/3 of the radiator and it works fine.
Old Nov 2, 2013 | 01:56 PM
bigaaron's Avatar
bigaaron
i thought about that, but I do not want a soggy mess on my hands after thermal cycles. Thought about making a cardboard template them doing it in wood, but not sure on the air flow characteristics and do not want to create hot spots for the radiator or trans cooler either. Maybe I will just leave it alone.
Note: with the middle of the temp guage hitting 210 degrees, mine runs about 180 in the summer hence the logic behind using a screen in the winter
Old Nov 2, 2013 | 08:52 PM
Moochoff's Avatar
Moochoff
I ran with just cardboard ziptied in behind the grill... As long as you pull it out when its not wet, it wont fall apart. Also used black spray paint on it bc the brown sticks out pretty bad
Old Nov 3, 2013 | 11:49 AM
pcfixerpro's Avatar
pcfixerpro
Instead of doing it behind the grill, I always did mine in between the radiator and ac condenser. There are cut outs on the top of the radiator (get eye level) and you will see two slits that work perfect for zip ties. I reinforced with duct tape where the zipties were going. Never once had a problem with water being that far back. And yes I painted it to color match the truck.
Old Nov 3, 2013 | 05:37 PM
zman17's Avatar
zman17
Retired Moderator - RIP
Plexi glass.
Old Nov 4, 2013 | 09:14 PM
charlie1935's Avatar
charlie1935
Find a upholstery shop and have them make a winter front that can snapped open to several sized openings like the big trucks have.
I've done this in the past.
Old Nov 5, 2013 | 11:26 AM
Ramman18's Avatar
Ramman18
http://www.showtimefab.com/products.html
Old Nov 6, 2013 | 11:48 AM
bigaaron's Avatar
bigaaron
thanks - if they are going solid grilles I assume there would be no issue with the flow
