Odd o2 issue
Old Nov 23, 2013 | 10:24 PM
atthewmartin114's Avatar
atthewmartin114
ok just start the truck test for power on will be 5 volts and one will be about 13.0-14.0 with the truck running. you need to test the feed to the pcm with a ohms meter to see if its over 1 volt. if it is the o2 is no good or your running really rich for some reason.
Old Nov 23, 2013 | 10:38 PM
Novarider's Avatar
Novarider
It's a new o2 sensor. I haven't had time to diagnose any further. I can tell you the truck runs fine but the throttle feels dead at low rpm and will only downshift 1 gear instead of 2 when floored.
Old Nov 24, 2013 | 12:10 AM
jpsycoboy5's Avatar
jpsycoboy5
I don't think I saw it in previous posts but what brand o2 sensor did you get? Bosch and other cheaper brands don't agree well with these trucks
Old Nov 24, 2013 | 05:30 AM
Novarider's Avatar
Novarider
Ntk o2 sensor.
Old Nov 24, 2013 | 12:59 PM
Johnn123's Avatar
Johnn123
I've been having this issue for months, still havent found a fix for the codes yet. Gonna subscribe so I can keep an eye on this
edit: odd question you aren't having any cooling/temp issues are you?
