Vacuum line
Old Nov 7, 2013 | 07:06 PM
tspayne1's Avatar
tspayne1
Default Vacuum line
I got the vents issue that switches to defrost while accelerating. I was checking the vacuum lines and found a loose one just above the pcv valve but can't figure out where it goes. Anyone have any ideas?
Old Nov 7, 2013 | 07:16 PM
Spillage's Avatar
Spillage
From memory, that missing line is the one that goes to the reservoir.
Old Nov 7, 2013 | 07:56 PM
dhvaughan's Avatar
dhvaughan
see the pics in this thread.
https://dodgeforum.com/forum/2nd-gen...m-line-go.html
Old Nov 7, 2013 | 08:47 PM
tspayne1's Avatar
tspayne1
The second pic shows the line I'm looking for going in behind the distributor cap. I can't seem to find it from above so I'll go under the truck in a day or 2. I don't know of it matters but mine is a 2wd... Thanks for the pics
Old Nov 7, 2013 | 09:45 PM
dhvaughan's Avatar
dhvaughan
i'll repost them here
the line in the second pic that goes to the rear, and down the firewall - i think that goes to the tcase for 4wd.
the line that 90* off to passenger side, goes over to a big wad with another split. those go to the reservoir (under the cowl on my 01) and into the firewall (i think) for the climate control.
Old Nov 8, 2013 | 01:21 AM
army_greywolf's Avatar
army_greywolf
I had to plug in a vac reservoir from a 97 blazer, the one under the cowl was cracked and leaking. it's just taped up and out of the way, solved the problem.
