has anyone used sea foam in there trucks
i run marvel mystery oil. in the gas tank 4 oz to 10 gal gas. not for diesel, or methanol fuel. do NOT over dose. it will take a few tanks to see the out come. some get a small help in MPG. been using it for 30 years. it will lube the valve stems, pistons, keep carbon out, start faster. also i use it in my R /C nitro engine as after run oil, just run a few drops through by spining it through the carb. but NOT in the nitro fuel.
Yea I seen on you tube them putting it in the vacuum line and some of them blew up they boged down real bad and towards the end of the can just blew but I seen some that ran great after all the smoking your supposed to put it in slow right I seen some just dumping it in as fast as possible
It feeds all the cylinders to get the seafoam into the engine to help clean and set in to do its thing. Either way it'll help if you have a gunky engine
It gets sucked down into the cylinders, with air, and the top of the cylinders.
The gas way it could only clean the fuel injectors and some of the cylinders.
Gas is good too but it's best to do both
Ingredient Name CAS Number % wt or
% vol
Toluene 108-88-3 60-70
Acetone 67-64-1 20-30
Hexanes 110-54-3 5-10
Methanol 67-56-1 <5
This Seafoam formula has been used for many years, back to the late thirties.
MSDS on Seafoam:
SECTION I IDENTITY AS USED ON LABEL AND LIST
Motor Treatment and Trans Tune
Sea Foam Formula: Proprietary Blend Date Prepared: 4-1-2002
Emergency #: (800)535-5053 MFG. Code ID: 34066
SECTION II-A HAZARDOUS COMPONENTS
NO. COMPONENT EPC# % BY WT.
1 PALE OIL 4229 40-60%
2 NAPHTHA 20 25-35%
3 IPA 125 10-20%
Here's the MSDS breakdown on Berryman's Chemtool B 12 and Seafoam.
Seafoam can be made at home for a fraction of the retail price, I prefer Berrymans B12 for a fuel system cleaner.
1. Pale Oil=Trans fluid
2. NAPHTHA=Coleman Lantern Fuel
3. IPA=Isopropyl Alcohol
Just prefix your google search with MSDS, it's mandatory for manufactures to list the contents of their products.
