Turning over but not start
Old Dec 10, 2013 | 02:55 PM
CrimsonTide1500's Avatar
CrimsonTide1500
Default Turning over but not start
I have a 2000 Ram 1500 Sport with the 5.2 V*.
I tried starting it this part weekend and it was turning over, just not starting. I tested the spark directly from the ignition coil and that is functional. I pulled a plug wire off the plug and stuck the screw driver up the boot of the wire and didn't get popped when we tried cranking the truck.
Any ideas, my initial thought is the rotor/cap for the distributer, but is there something else I might be missing like a sensor or a relay?
Old Dec 10, 2013 | 07:43 PM
chromed95's Avatar
chromed95
Is that the proper way of testing? Sounds like the proper way of death...why don't you try taking the spark plug out of the head but leave it in the boot and touch it against the block or head and then try cranking to see if you get spark or see what color spark you have. But hold it in the safest way possible to where you aren't going to get shocked. If your coil is working, then I'd be looking at dist cap and rotor. Make sure plug wires are routed per TSB on here too.
