Turn signal issue
On my 97 1500, the left front turn signal stopped working. It has power at the plug, so it seems obvious that the issue is with the ground. The headlight works. Is there a likely place to start looking without tearing all the wiring apart? There is a wire grounded to the truck body near there and when I test the turn signal using that wire as the ground, it works. Any suggestions would be appreciated.
