Oil level high on dipstick... help please
Old Jan 6, 2014 | 03:53 PM
770 raptor's Avatar
770 raptor
Default Oil level high on dipstick... help please
So I completed the plenum repair and reassembled. Changed the oil and replaced with correct amount, however now while the engine is running, the oil level is almost to the top of my dipstick. When the engine is off, it is normal. This was not the case prior to repairing the intake plenum. This leads me to believe that I'm having excessive crankcase pressure. The pcv valve is new. Any ideas what might also be causing this problem? Could there be an issue with the plenum plate cause the intake charge to vent into the valley?
Old Jan 6, 2014 | 06:14 PM
chromed95's Avatar
chromed95
Ive never heard of someone checking their gasoline motor oil level with the engine running before, this is new. This practice is mainly used with diesel farm equipment and semi trucks, I know because I do it myself with farm equipment. I think you're fine. If you did everything right and put it back together right, don't sweat it unless its acting up.
Old Jan 7, 2014 | 10:55 AM
r-g_richards's Avatar
r-g_richards
Engine oil is only checked with the engine off and at rest for at least 5 minutes. This gives enough time for the oil to drain to the pan to be checked.
Old Jan 7, 2014 | 11:12 AM
I've seen oil shoot out of the tube when removing the dipstick with the engine running. Check it with the engine off.
Old Jan 7, 2014 | 01:20 PM
Kaldir's Avatar
Kaldir
+1 To what ever one else said. Only check the oil when the engine is off. If its correct, then don't worry about it.
