99 dodge ram wont crank
Old Jan 15, 2014 | 06:06 PM
sam3293's Avatar
sam3293
Default 99 dodge ram wont crank
Truck has power lights and everything work but as soon as I go to turn the key i get a click and all the dash lights and interior lights go away.
Old Jan 15, 2014 | 07:35 PM
sam3293's Avatar
sam3293
Slight update I was able to get the truck out of the dt bank parking and back home so that was good. I pulled the rear most spark plug on both sides they looked clean then i disconnected the battery negative then positive and put them back on truck started right up. Any ideas on the cause of why this worked or what needs to be fixed.
Old Jan 15, 2014 | 07:49 PM
merc225hp's Avatar
merc225hp
That is what got you back up and running, check all the batt ends, then all the grounds. Clean and or replace cable ends, batt terminals.
Old Jan 15, 2014 | 08:00 PM
sam3293's Avatar
sam3293
Thanks makes sense.
