Changed Plenum, Now Have New Issue
Old Jan 18, 2014 | 06:29 PM
Draxxon's Avatar
Draxxon
Unhappy Changed Plenum, Now Have New Issue
Hey there all. Sorry to say but I need to pick your minds. I had to change my plenum gasket due to regular issues and now I have a new problem.
My truck idles a little rough, but once I get to about 40 my truck starts shaking like a leaf in a hurricane! I didn't have this issue before I changed the gasket, so do any of yall have a clue?
Much thanks in advance!!
98 Dodge Ram 1500 5.9 V8.
Old Jan 18, 2014 | 07:15 PM
stewie01's Avatar
stewie01
How's the spark plugs? Change or do anything with them during the plenum work?
Kinda sounds like a misfire...
Probably need to change the Pre-Cat O2 sensor and see if the cat is clogged
Old Jan 18, 2014 | 09:01 PM
ryan0714's Avatar
ryan0714
take the pre cat o2 out and see if it runs better. sometimes a vacuum leak can cause this too. but id check the o2 sensor first
Old Jan 19, 2014 | 01:42 PM
Draxxon's Avatar
Draxxon
Thanks for the quick reply's! I never did anything with the spark plugs, but knowing my luck they will need to be changed so I am going to go ahead and do that. As for the o2 sensor, will running without it hurt anything? (just a test drive) Thanks again!
Old Jan 19, 2014 | 03:04 PM
Johnn123's Avatar
Johnn123
No it won't hurt a thing. PCM will just operate in warm up mode and run a set air/ fuel mixture. Remove the sensor from the exhaust, and disconnect the wires from the connector so the sensor isnt reading just air...
When you reinstall the sensor please disconnect the negative battery cable.
Old Jan 19, 2014 | 07:57 PM
Draxxon's Avatar
Draxxon
Thanks! I will check it all out tomorrow morning. Will update as soon as I have test driven it.
Old Jan 20, 2014 | 05:37 PM
Draxxon's Avatar
Draxxon
*Update* Took out the o2 sensor and unplugged it. It still shakes bad, but now it's even worse. Now it will just die when coming to a stop. Also quite hard to start once it dies. Think it's time for new plugs, wires and dis cap??
Thanks again to you all for the advice and help!
Old Jan 20, 2014 | 07:07 PM
stewie01's Avatar
stewie01
I might be wrong but I think you just need to remove the O2 sensor from the pipe and leave it plugged it...
You could pull a few plugs and see how they look, start with #8.
Old Jan 20, 2014 | 11:11 PM
Draxxon's Avatar
Draxxon
Will try that. Thanks!
Old Jan 21, 2014 | 12:10 AM
Draxxon's Avatar
Draxxon
Left it plugged in and no change. Ever have one of those days where you just want to light your truck on fire and watch it melt? Today is that day for me! LOL!
