Transmission ID
Old Jan 21, 2014 | 06:16 PM
Kennyp's Avatar
Kennyp
Default Transmission ID
Hey guys,
Transmission just went out on my truck this past week. I put it up on the lift at work to see if I could find the model number. I've came across 3 different tags, all of which looked like serial numbers on each of them. Since I work for a Toyota dealership, I don't have access to a reference or breakdown sheet for the truck.
My truck is a 2001 Ram 1500, 2 Wheel drive shortbed, 1/2 ton, 5.2L 318, With an A/T-O/D trans.
I've did some research and narrowed it down to the 46RH/RE.
From what I've found anything pre 95 and manually controlled is the 46RH.
Anything after and electronically controlled is the 46RE.
Would this be correct?
Thanks for the help guys.
Old Jan 21, 2014 | 11:05 PM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Jan 22, 2014 | 07:58 AM
stewie01's Avatar
stewie01
Yup. You have the 46RE.
