Convert Fuel Pump
Old Jan 24, 2014 | 01:00 AM
Zeppelinrocks's Avatar
Zeppelinrocks
Default Convert Fuel Pump
Is there anyway to convert our fuel pump to have an in line pump and filter so I don't need to drop the take to change it if it fails again.
Thanks
Old Jan 24, 2014 | 07:07 AM
rocklong's Avatar
rocklong
I put one inline just above the tank. It sucked fuel through the old burnt out pump so I never had to remove it. I had to put in a fp regulator and set it at 50lbs and also a return hose that u can just hook up the the unused port on fuel module assembly. I don't know if this is the proper way to do it but it worked for me, probably went 10-12000 miles with no troubles. Just use high pressure fuel lines or they will blow out.
