Relay for daytime running lights?
Old Oct 11, 2005 | 03:21 PM
CanadianRAM's Avatar
CanadianRAM
Default Relay for daytime running lights?
I've got a 96 RAM, 1500 and seem to have blown the relay for my daytime running lights. Manual is no help. I've already replaced the fuse and bulbs to no effect. Can anyone tell me which relay is the correct one to replace? Thanks!
Old Oct 13, 2005 | 06:08 PM
CanadianRAM
Default RE: Relay for daytime running lights?
Anyone got any ideas on this one? Any help would be appreciated.
Old Oct 14, 2005 | 01:40 PM
95DODGERAM1500's Avatar
95DODGERAM1500
Not the answer you are looking for but mine have never worked. So if you find out let me know.
Old Oct 15, 2005 | 07:06 AM
Chump's Avatar
Chump
Sounds like you have a bad DRL module?
DRL Description and Operation
CIRCUIT OPERATION
On vehicles built for sale in Canada, the low-beam headlamps operate when the ignition switch is in the RUN position and the park brake switch is OPEN.
Circuit L10 from fuse 15 in the fuse block supplies voltage to the DRL module. Circuit A3 from the Power Distribution Center (PDC) connects to DRL module.
The DRL module receives information on park brake switch position on circuit G11.
Circuit L4 powers the low beams of the headlamps. When the headlamp switch is OFF, the DRL module powers the low beams on circuit L4. When the head-lamps are ON, the multi-function switch powers the low beams on circuit L4.
Circuit L3 feeds the high beams of the headlamps. When the operator flashes the headlamps with the stalk of the multi-function switch, the DRL senses voltage on circuit L3 and stops supplying power to the low beams on circuit L4. Circuit Z1 provides ground for the DRL module.
