Hydroboost?
Old Feb 19, 2014 | 01:45 PM
Gaius's Avatar
Gaius
Default Hydroboost?
I have a 5.9 in my Jeep, and swapping axles that will need Hydroboost. The master cylinder/booster on my Jeep is the same pattern as the Dodges.
What have you done with hydroboost? Will the stock pump be sufficient?
Thanks!
Old Feb 19, 2014 | 01:50 PM
merc225hp's Avatar
merc225hp
Why hydroboost, what diff's are you using?
Old Feb 19, 2014 | 02:59 PM
Wh1t3NuKle's Avatar
Wh1t3NuKle
Thanks!
You're probably going to run a ram assist or full hydro?
From my research our stock pump on the Dodge is more than sufficient. The main issue will be choosing the appropriate ram size (diameter/stroke). In general, don't go any larger that 2" diameter.
However, it's unclear what you have going on other than a 5.9 engine in the Jeep. Vanco has direct bolt in hydroboost, but it's pricey.
