Want a bigger Ram 2500?
Old Feb 19, 2014 | 05:29 PM
ronsWash's Avatar
ronsWash
Default Want a bigger Ram 2500?
Hello all, I'm looking at camping on a regular basis. I now have a 2001 Ram 1500 with a tow package. I haven't bought a camper yet but, I'm looking at a 22 to 26 ft camper. I would like to buy a used Ram 2500 to give me more towing ability. Would the 2500 be a good choice and what axle should I look for?
Old Feb 20, 2014 | 01:53 AM
jasonw's Avatar
jasonw
Site Moderator
Welcome to DF. Will move you to the correct spot.
For future reference:
https://dodgeforum.com/forum/dodge-r...ead-first.html
Old Feb 20, 2014 | 08:07 AM
stewie01's Avatar
stewie01
Honestly, if you want towing ability simply buying a Ram 2500 doesn't get you anywhere, after all, it'll have the same under powered 5.9L under the hood and possibly the same crappy 46RE.
If you have the funds get a 2nd Gen Cummins with a manual transmission. If you want to tow on a regular basis your wallet will thank you in the long run.
Better fuel economy when towing (and regular driving) and better reliability.
Old Feb 20, 2014 | 11:25 AM
Thornloe Pride's Avatar
Thornloe Pride
^1. The ram 2500 v8 only gives you another 1000lbs tow rating compared to the half ton. I believe the ram 2500 v8 has a tow rating on 8500ish lbs whereas the 1500 is 7500ish lbs. There isn't much difference except the suspension can handle the rated tow rating better. My advice is look for a v10 2500 or a diesel. They are both rated to tow close to 12,500 lbs.
The 2500 v8 has a Dana 60 rear while the v10 or Diesel have Dana 70 if automatic and a Dana 80 if standard. The v10 and diesel also have a 47re/rh transmission which is stronger than the 46re in the 1500 and 2500 v8
