wiring problems
Old Mar 10, 2014 | 01:56 PM
glasssman's Avatar
glasssman
Default new member wiring problems crankshaft position sensor
i have a 1998 dodge 1500 sport 5.2 just bought it and started having some trouble only has 130k miles strong engine. i climbed under it with intentions of changing the crankshaft position sensor. i started following the wires coming out they go over the transmission and there was a connector there which is half gone they have the wires twisted together at the back of the connector and on the front they have clips attached to the small pieces of wire that are remaining. to make it worse the wires go up from there so i opened the hood and they have apprx 7-8 wires connected there as well right next to the distributor cap i found all this when it died on me i put my hand on them and seperated them it fired right up i took off and it died again i am afraid i have knocked some of the connections loose and i am in a no start situation. i would like to get it back to having the correct wires and connections. where are they supposed to plug to at the distibutor area and what can i do to fix it
Old Mar 10, 2014 | 06:10 PM
SpcD1500's Avatar
SpcD1500
Do you have pictures?
