front end noise
I been having some problems. theres been some noise comeing from the front, when driving down curvers when i turn the the wheel to the right there is some rubing noise. I took it to the mechanic to look at it they told me it was the bushings, so i changed the bushing. still have the same prblem. then they told it might be the bearings. i haven t messed with the bearings yet but i was just wondering if any one has had the same problem and if u can give and idea what to do.
i have 2000 dodge ram 1500 2wd
Just throwing this one out there...before I got my Dodge I had a Chevy Silverado with one size larger tires than stock. I also had front and rear mud flaps. When going around curves I was just catching the inside lower edge of the plastic mudflap and getting a scraping rubbing noise. I just had to trim the inside lip of the flap and it went away. Hopefully it is something that simple for you.
