Breather Tube sucking air.
Old Apr 19, 2014 | 02:47 PM
Bad_Moose's Avatar
Bad_Moose
Default Breather Tube sucking air. Answer Plenum Blown Out Again. :-(
OK I did the Hughes plenum last fall everything has been 100%.
Now in the last week I have started having a noise, thought it was a bad alt or idler pulley.
But come to find out, my breather is sucking air like its connect to a super charger. Inside the manifold looks dry.
Engine is running smooth, idles smooth, and has plenty of power. Just sounds like crap.
Any ideas, cause I'm thinking the gasket pulled out for some reason, and just not showing oil in the intake yet.
Last edited by Bad_Moose; Apr 19, 2014 at 05:56 PM. Reason: Answer Plenum Blown Out Again. :-(
Old Apr 19, 2014 | 04:57 PM
Bad_Moose's Avatar
Bad_Moose
I just answered my own question. The plenum gasket has for some reason blown out again, this is 10x worse than when I finally got around to doing the stock one.
I have been building engines for over 30 years, and took my time doing the Hughes kit.
I haven't even put 2000 miles on it since I did it last fall.
I guess lesson learned DON'T BUY THE GASKET KIT. SPEND THE EXTRA $$ AND GET THE ENTIRE INTAKE KIT.
