Need pinout for OBDI ECU
Old Apr 27, 2014 | 03:00 PM
94Beater's Avatar
94Beater
Default Need pinout for OBDI ECU
I'm doing some electrical work on my truck.
Need to get some sensors and other signals form it (ECU)
I'm referring to the single large (I believe it's 60 pin) connector going into the ECU unit on the firewall.
I could not find this info in any manuals
Thanks
Thanks
Old Apr 27, 2014 | 04:01 PM
stewie01's Avatar
stewie01
Did you check the Factory Service Manual? If not they're available in the DIY/FAQ Section.
Old Apr 27, 2014 | 04:17 PM
merc225hp's Avatar
merc225hp
^^^ Yep page 771 in the 95 FSM, I don't have the 94 FSM but they should be the same.
CAV CIRCUIT FUNCTION
: Kl 18D6/RD MAP SENSOR SIGNAL
2 K2 18TN/BK ENGINE COOLANT TEMP SENSOR SIGNAL
3 A14 16RD/WT FUSED B +
4 K4 20BK/LB SENSOR GROUND
5 — 6 K6 20VT/WT 5V OUTPUT
7 K7 200R 8V SUPPLY
8 — —
9 F18 20L6/BK FUSED IGN SW OUTPUT (START/RUN)
10 T6 200R/WT TRANS OD SWITCH OUTPUT
11 Z12 16BK/TN GROUND
12 Z12 16BK/TN GROUND
13 K14 18LB/BR INJECTOR #4 DRIVER
14 K13 18YL/WT INJECTOR #3 DRIVER
15 K12 18TN INJECTOR #2 DRIVER
16 K l l 18WT/DB INJECTOR #1 DRIVER
17 K17 18DB/TN INJECTOR M l DRIVER
18 K18 18RD/YL INJECTOR #8 DRIVER
19 K19 16BK/6Y IGNITION COIL DRIVER
20 K20 18D6 GENERATOR FIELD CONTROL
21 K21 16BK/RD INTAKE AIR TEMPERATURE SENSOR SIGNAL
22 K22 180R/DB THROTTLE POSITION SENSOR
23 K141 18TN/WT LEFT HEATED OXYGEN SENSOR
24 K24 206Y/BK CRANKSHAFT POSITION SENSOR SIGNAL
25 021 20PK SCI TRANSMIT
26 —• —-
27 C20 18BR A/C REQUEST SIGNAL
28 — — 29 V40 20WT/PK STOP LAMP SWITCH OUTPUT
30 T41 20BK/WT PARK/NEUTRAL POSITION SWITCH SENSE
31 G14 18PK/BK TRANSMISSION TEMP LAMP DRIVER
32 63 20BK/PK MALFUCTION INDICATOR LAMP
33 V36 20TN/RD VEHICLE SPEED CONTROL-VACUUM SIGNAL
34 C13 20DB/0R A/C COMPRESSOR CLUTCH RELAY CONTROL
35 K35 206Y/YL EGR SOLENOID CONTROL
36 — . . . .
37 T18 20L6/0R TRANSMISSION CONTROL MODULI-
38 K38 186Y FUEL INJECTOR U 5 DRIVER
39 K39 186Y/RD IDLE AIR CONTROL MOTOR DRIVER
40 K40 18BR/WT IDLE AIR CONTROL MOTOR DRIVER
41 K41 18BK/D6 RIGHT HEATED OXYGEN SENSOR
42 T54 18VT TRANSMISSION TEMPERATURE SENSGH
43 621 20GY/LB TACHOMETER SIGNAL
44 K44 20TN/YL CAMSHAFT POSITION SENSOR SIGNAL
45 020 20L6 SCI RECEIVE
46 —
47 67 20WT/0R VEHICLE SPEED SENSOR SIGNAL
48 V31 20BR/RD VSC SWITCH - SET
49 V32 20YL/RD VSC SWITCH OUTPUT fON)
50 V33 20WT/L6 VSC SWITCH RESUME/ACCEL
51 K51 20DB/YL AUTOMATIC SHUT DOWN SIGNAL
52 K52 20PK/BK EVAP/PURGE SOLENOID SIGNAL CONTROL
53 V35 20L6/RD VEHICLE SPEED CONTROL VENT SIGNAL
54 654 200R/BK UP SHIFT LAMP DRIVER
54 K54 200R/BK TCC SOLENOID CONTROL
55 T60 20BR OVERDRIVE SOLENOID CONTROL
56 624 20GY/PK SERVICE REMINDER INDICATOR DRIVER
57 A142 16DG/0R ASD RELAY OUTPUT
58 K58 18BR/DB INJECTOR #6
59 K59 18VT/BK IDLE AIR CONTROL MOTOR DRIVER
