side trim on door.
The rubber molding on the driver door is coming loose. What glue can I use that will hold it in place ?. I checked LMC Truck and you can only buy a complete side molding set for $120. dollars, but I don`t need a complete set. The molding piece on my truck is fine, other than it just coming loose.
I will give it a try and see if it works.
I've used
and have had excellent results.
(3M 08001 Yellow Super Weatherstrip and Gasket Adhesive)
I've used this stuff from 3M and have had excellent results.
I forgot all about this stuff, I have used it in the past with good results. I think I will order some of this instead.
Hey if you've used it before go for it! You should also take some before and after pics for us!
Another option would be to just remove it completely. Personally i like it without any stickers decals or moldings. to remove residue decals and excess glue get a rubber eraser wheel. I used it to remove the black tape on the exterior of my doors that was cracked. looks much better.
