Are these the parts I need
Old May 23, 2014 | 02:54 PM
topkin's Avatar
topkin
Question Are these the parts I need
So discovered a super loose... drag link/sway bar/tie rod? not sure of name. Conects to the pitman arm on one end, hub assembly on the passenger side and a sway bar conects in the middle-ish.
So looks like I can't get the whole assembly on rock auto and have to order 3 seperate parts. are these the right three?
http://www.rockauto.com/catalog/more...465&cc=1366589
Front Left Inner (To Pitman Arm); 4WD
http://www.rockauto.com/catalog/more...484&cc=1366589
Front Right Outer; 4WD; connecting tie rod
http://www.rockauto.com/catalog/more...765&cc=1366589
Front; 4WD
Just lookin for some conformation, the labeling (front, left, right, inner, outer) is whats confusing me. should I go with ACDelco or Raybestos insted of moog?
-Thanks guys
Last edited by topkin; May 23, 2014 at 06:06 PM. Reason: trying to make this easier to understand
Old May 23, 2014 | 04:03 PM
AtomicDog's Avatar
AtomicDog
Looks like you need an inner tie rod, outer tie rod and adjusting sleeve. I was able to re-use my original adjusting sleeve when I replaced my tie rods. I used Reybestos parts sourced from my local Pep Boys and they worked fine for me.
Old May 23, 2014 | 05:34 PM
topkin's Avatar
topkin
just ordered reybestos, thanks for the clairification. And thanks for the discount code DF.
