Hughes FI Airgap & Throttle body
Old Jun 4, 2014 | 10:43 PM
mr chips's Avatar
mr chips
Angry Hughes FI Airgap & Throttle body
Hi I've just had installed a new stroked 408 with the air gap and throttle body, with numerous other mods, but the old K&N Cold air intake will not fit, its hitting the firewall, Hughes swears it should be the same position and height as the kegger , well the dam thing won't fit and now I can't even break the fing engine in w/o a filter on it, bought a regular air cleaner and of course no one carries the offset bolt to screw a regular carb style cleaner on to it. I can't even purchase the small spectre plenum because it needs the offset bolt and there will be no way to instal the plenum over the offset bolt and no way to thread it on after!!! AAARRGGG!!
does anyone know what I can do!! Im not getting any answers from the people that should have them, so I'm asking all of you. Help!!!
__________________
rob
Old Jun 4, 2014 | 11:52 PM
Wildman4x4nut's Avatar
Wildman4x4nut
Veteran: Army
Bend it yourself??? Can't be that hard. Or use the hat from the K&N and just put a filter on it. Or are you saying the hat is hitting the firewall? Do you have a TB spacer? How about some pic's of how it is hitting so we might get ideas to help.
Old Jun 5, 2014 | 02:20 AM
Ram Driver's Avatar
Ram Driver
Will this work for your set up ?.
http://www.summitracing.com/parts/sp...FaY-MgodRAcALA
