installing limit straps
Old Aug 9, 2014 | 09:53 PM
jeff351's Avatar
jeff351
Default installing limit straps
Since I put in the long arm conversion and removed the sway bar, I had nothing preventing the axle from dropping out from under the truck, other than brake lines.
Ordered a pair of 18" limit straps from here...http://www.ruffstuffspecialties.com/...MITSTRAPS.html
Not sure why they say "*** VAULT"
So...jacked up front of truck under frame until brake hose & driveshaft angle are at their limits...let down a bit, and measured.
Drilled out a hole through the upper coil mount and welded in a cut-off bolt from both ends; for the bottom mount, cut the head off a bolt, ground a flat along one edge, welded a washer in (for the nut to have something to bottom out against) and welded it all in. Took about 1 hour total.
