"check engine" light
Old Oct 21, 2005 | 06:31 PM
Dodge4x4810's Avatar
Dodge4x4810
Default "check engine" light
Bought a truck in June ('99 ram 4x4 qc 5.9) first it had the plenum, got that fixed. It shook like it had a misfire during that problem, after it was fixed it still shook and the "check engine" light came on "cylinder 8 misfire", local mechanic thought it was a fuel related problem, so (under warranty) brought it back to the dealer and he replaced the injector and cleaned the fuel rail. Soon, after the "check engine" light came back on with same problem, but i think that the injector helped it because it now has a more healthy ro throaty exhaust tone, but still shook and light came on. Brought it back to the dealer, he brought it to the Dodge Dealership and they worked on it for hours and could not find anything wrong with it??? Any ideas???
Thanks
Old Oct 21, 2005 | 06:33 PM
Dodge4x4810
Default RE: "check engine" light
oh ya, its not a violent shake (like its gonna stall), just a rumble.
Old Oct 21, 2005 | 06:49 PM
steve05ram360's Avatar
steve05ram360
do the codes still say misfire on #8?
Old Oct 21, 2005 | 07:39 PM
shott8283's Avatar
shott8283
mine shakes like a M-240 golf machine gun... but it runs fine...wierd...its always done that..worse when its cold and smooths out after driving for a while
Old Oct 21, 2005 | 07:50 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
My truck is doing that right now and I had it diagnosed as a misfire on #6. Check the passenger side of the engine, and I bet there are signs of oil along the bottom of the head. If your truck is like mine, the intake gasket is failing. Mine rumbles, idles rough, etc. I only drive when necessary, but when I get some money next month I am going to replace the intake gasket and pan and also have my heads worked. I wouldn't be surprised if I have a burnt valve in #6.
Old Oct 21, 2005 | 08:28 PM
Dodge4x4810
STEVE00RAM360, the "check engine" light went off just before i brought it up there. THe guy said that it did not throw any codes, but it should still store them after the light goes off right?
Old Oct 21, 2005 | 10:55 PM
Dodge4x4810
My truck definitely has a misfire, there is an irregular pulse that i can feel out the exhaust.
