Cam install not good, some advise please
Old Nov 20, 2014 | 07:09 PM
  #41
beeker's Avatar
beeker
Originally Posted by 1997JollyGreenGiant
Cool! So you going to make a video so we can hear the new cam?
Posted a walk around vid already, page 4, post 35. I plan to do a driving vid to really hear how it sounds through the RPM range in-use. Motor sounds louder than I remember too, but a good loud.
Got fuel sync checked and set today at a local garage. Was near dead on at -1, he adjusted to where it fluctuates between 0 and +1 and then rechecked after adjustment. Only charged me $20.
Next I'll be contacting Hemifever for some fine tuning.
Old Nov 20, 2014 | 09:36 PM
  #42
beeker's Avatar
beeker
Here's a breakdown of parts and cost. I had no idea I spent so much on this! I bought parts little at a time over a 2 year period and just kept adding more that I wanted to do.
$980 EQ Monster Magnum Heads(2.02 Intake Valves) from Clearwater Cylinderhead
$343 CompCams 206X4 112LSA from Hi-potek
$329 Harland Sharp Rockers S70037 fixed 1.7 ratio from SoutheastRT
(already owned these rockers and that's the only reason cam was ground for use with 1.7 rockers, it's highly advisable to stick with 1.6 rockers when doing a cam and get adjustables!)
$136 Hughes Hydraulic Lifter set from Hi-potek
$95 Hughes Valve Spring set (not used) from Hi-potek
$85 Felpro Headset(complete upper engine kit) HS 9898 PT-2 from Ebay
$70 ARP Headbolts from Hi-potek
$66 Melling High Volume Oil Pump M-72HV from Ebay
$62 Hughes Valve Retainers (not used) from Hi-potek
$50 Duplicolor High Temp Engine Paint from Napa
$48 Timing Chain Tensioner from Hi-potek
$46 Hi-potek Shipping
$45 Mopar Hardened Pushrod set P5249662 from chyslerpartsdirect.com
$32 Valve Spring seal set (not used) Hi-potek
$32 Oil/Filter Walmart
$27 Supertech Coolant from Walmart $9ea
$22 Felpro Rear Main Seal BS40651 from Ebay
$22 Mopar PCV Valve S3-05052-00146 from Ebay
$21 Felpro Oil Pan Gasket OS34409R from Ebay
$17 CompCams Pushrod Length Checker(not used) 7905-1 from Ebay
$17 Moroso Oil Pump Prime Tool 62250 from Ebay
$16 Cam Bolt/Washer (not used/didn't fit) from Hi-potek
$15 Cylinder Carbide Rotary Burr SB-5(for porting heads) from Ebay
$15 Hughes Valve Spring Keeper set (not used) from Hi-potek
$14 Timing Gasket from Hi-potek
$13 Airtex VC Breather Elbow 7F1013 from Ebay
$13 Crank Bolt from Hi-potek
$11 Thermostat Housing Tube 85181 from Rockauto
$9 Autolite Spark Plugs 5224(for 195 stat) from Walmart
$7 SMP VC Breather Grommet GV31 from Ebay
$7 CompCams Breakin Oil from Ebay
$6 Ultra Gray RTV from Walmart
$5 Stant 195 Thermostat 13009 from Ebay(180 too cold in winter)
$5 Mopar PCV Grommet 53030017 from Ebay
$4 Cam Key from Hi-potek
$2685 FIRST BUILD TOTAL
Rebuild
$459 Harland Sharp adjustable Studmount Roller Rockers S7307, 3/8ths Mounting Studs, Guide Plates from SoutheastRT
$245 Powder Coat JBA Headers local shop
-$230 Sold Harland Sharp fixed ratio Rockers S70037
$145 Valve Job
$60 Replacement Exhaust Valve from Clearwater Cyl Head
$52 Felpro 519SD Head Gaskets from Ebay
$32 Long's Transmission Cooler Thermal Bypass Valve from Ebay
$32 Oil/Filter from Walmart
$25 Felpro Intake Gasket MS953921 from Ebay
$20 Fuel Synced by local shop
$13 CompCams 106 Valve Train Assembly Spray from Ebay
$11 Felpro Exhaust Manifold Gasket Set MS95480 from Ebay
$10 Replacement Hydraulic Valve Lifter Sealed Power HT-2269 from Ebay
$9 Replacement CompCams Hardened Pushrod 7631-1 Ebay
Filtered and reused Coolant
Reused ARP Headbolts
$876 REBUILD TOTAL
$3561 COMBINED TOTAL
