2500 to 1500 suspension question
You can't swap the leaf springs, since the 2500 leaf springs are wider. You can "Add-A-Leaf" though. Info found :http://www.sdtrucksprings.com/index....oducts_id=6315
In the front, you can take the front coil springs from a 2500 and put them on your 1500 and add a little height.
But thats kindve stupid.
It would be much better to swap out the rear axle, then you just have to change the hangars and shackles.
but yes it cannot be done "easily"
This is partially wrong. You cannot swap the leaf springs directly. You could put the 2500 hangars and shackles on. And then weld 3in perches on.
