heat/Air. only out defroster vent.
Old Nov 23, 2014 | 06:51 PM
eblack's Avatar
eblack
Default heat/Air. only out defroster vent.
Any suggestions on why I only have air flow out my defroster vents of my 01 ram? Temperature works fine just no air flow control.. thanks for any help!!
Old Nov 23, 2014 | 07:10 PM
Ham Bone's Avatar
Ham Bone
Broken vac line. Check lines that Come off the t in the psssnegee side of the intake. one goes up in to the firewall. If it's broken and retracted back into the dash you're kinda boned.
Old Nov 23, 2014 | 10:22 PM
Spillage's Avatar
Spillage
Search this forum for "wild vents"... plenty of info on the issue.
Old Nov 24, 2014 | 06:42 PM
eblack's Avatar
eblack
Thanks guys, found a cracked hard plastic vac line off the firewall but right before the check valve.. All I did was pull the old piece out of the rubber boot from the check valve and I had enough slack to slide it back over the existing plastic line.. works perfect!!!! So thanks again!!!!!
