Can cracked exhaust manifold cause rough idol?
Old Dec 3, 2014 | 12:33 PM
Ace8929's Avatar
Ace8929
Default Can cracked exhaust manifold cause rough idol?
The manifold on my passenger side is cracked all the way around and when i start the truck it idles rough and gets rougher when i put it in gear it gets worse. It evens out when i give it some gas and then its fine.
Old Dec 3, 2014 | 01:00 PM
dumpfixxer's Avatar
dumpfixxer
Default cracked manifold
in short, yes it will. it will give the comp a false o2 sensor reading causeing either a lean or rich mixture causeing the computer to compensate for it,
Old Dec 4, 2014 | 09:07 AM
Ace8929's Avatar
Ace8929
But wouldn't that cause a check engine light.
Old Dec 4, 2014 | 09:14 AM
TNtech's Avatar
TNtech
Site Moderator-Dodge Tech
Not if the O2 was within operating range as viewed by the PCM. If there was a huge difference between banks (adaptives) then it would throw codes. I'm inclined to think the problem is a worn motor or trans mount in this case.
